-2
I found this video on YouTube, and I want to try doing the same, the problem is that I dont know how much voltage the GPIO18 has.
Link of the video: https://www.youtube.com/watch?v=86x6NweQsdY
I've been searching for information on google but I'm still not sure about it. It can be a 3.3V or 5V, but I don't know if I can choose, or not.
Any help will be apreciated.
Gabboxl
  • 175
The Raspberry Pi GPIO header has 40 pins. There are two 5V pins, two 3V3 pins, some ground pins, and the rest are general purpose - you can use them as input or output pins. These general pins are variable 3V3 - if you set up a pin as an output pin and set it high, it will give out 3V3 (3.3 volts). See https://pinout.xyz for a reference guide.
ben_nuttall
  • 2,451
