I building cluster computer with two Raspberry PI 3 where I have 1 internet router and one LAN switcher. Both Raspberry PI are connected to the switcher.
Internet router gateway is 192.168.1.1
LAN Switcher gives me gateway 192.168.137.1
I need setup one PI to 192.168.1.100
Second PI need to have 192.168.1.101
Now I stack on the /etc/dhcpdcd.conf
interface eth0
static ip_address=192.168.1.100
static routers=192.168.137.1
static domain_name_servers=192.168.137.1
I also try something like this:
interface eth0
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
But this not gives me internet access and can't access to this PI.
Any help?
  • Your question is unclear (possibly a language issue) See How to set up Static IP Address You can have only ONE gateway - post ip r output – Milliways Aug 31 '19 at 22:54
  • if the pi's are "behind" the "LAN Switcher", they would need a 192.168.137.x address - and appropriate routing in other parts of your network would need to be set up so that the 192.168.1.x network knows how to "reach" the 192.168.137.x network – Jaromanda X Sep 01 '19 at 02:24
  • @Jaromanda I not understand what you tell me. – Ivijan Stefan Stipić Sep 01 '19 at 07:11
  • @Milliways I trying to setup static IP to PI but behind PI is switcher and internet router. Switcher and router have different gateway addresses – Ivijan Stefan Stipić Sep 01 '19 at 07:12
  • I don't know what a "LAN Switcher" is. You need to explain your setup. A switch should not have a gateway and there must only be a single DHCP server on a network. This is becoming more a problem about your network NOT the Pi. Unless you can post some meaningful data e.g. ip r no one can help. – Milliways Sep 01 '19 at 07:30
  • Please edit your question and paste the output of these two commands from one RasPi to it: ip addr and ip route. – Ingo Sep 01 '19 at 08:01
  • @IvijanStefanStipić - perhaps you need to learn basic networking in that case – Jaromanda X Sep 01 '19 at 08:43
0 Answers0
