Raspbian Buster Lite, Raspi 3b+
I want to bond ethernet (eth0) and a USB wifi dongle (wlan1) for network/internet access. This part I've managed with success, dynamic failover works perfectly.
The problem is when I create an AP assigned to the Raspi's built-in wifi (wlan0). With the USB wifi dongle (wlan1) plugged in, I always lose AP access- wlan0 is shown as "down".
systemd-networkd with Dynamic Failover: network interfaces eth0 (Ethernet), wlan1 (USB Wifi Dongle)
#Create Systemd Network
-Es
cat >/etc/resolvconf.conf <<EOF
# Set to NO to disable resolvconf from running any subscribers. Defaults to YES.
resolvconf=NO
EOF
systemctl mask networking.service
mv /etc/network/interfaces /etc/network/interfaces~
systemctl mask dhcpcd.service
systemctl enable systemd-networkd.service
systemctl enable systemd-resolved.service
ln -sf /run/systemd/resolve/resolv.conf /etc/resolv.conf
cat >/etc/systemd/network/04-eth.network <<EOF
[Match]
Name=eth0
[Network]
# to use static IP (with your settings) toggle commenting the next 8 lines.
#Address=192.168.50.60/24
#DNS=84.200.69.80 1.1.1.1
#[Route]
#Gateway=192.168.50.1
#Metric=10
DHCP=yes
[DHCP]
RouteMetric=10
EOF
-Es
cat >/etc/systemd/network/08-wifi.network <<EOF
[Match]
Name=wlan1
[Network]
#Address=192.168.50.61/24
#[Route]
#Metric=20
DHCP=yes
[DHCP]
RouteMetric=20
EOF
cat >/etc/wpa_supplicant/wpa_supplicant-wlan1.conf <<EOF
update_config=1
country=US
network={
    ssid="My_Wifi"
    psk="My_Password"
    key_mgmt=WPA-PSK
EOF
chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlan1.conf
systemctl disable wpa_supplicant.service
systemctl enable wpa_supplicant@wlan1.service
Bond Network Interfaces eth0 and wlan1
############# Bond eth0 and wlan1 ###############
-Es
mv /etc/systemd/network/04-eth.network /etc/systemd/network/04-eth.network~
mv /etc/systemd/network/08-wifi.network /etc/systemd/network/08-wifi.network~
cat >/etc/systemd/network/02-bond0.netdev <<EOF
[NetDev]
# status: cat /proc/net/bonding/bond0
Name=bond0
Kind=bond
[Bond]
Mode=active-backup
# primary slave is defined in *eth.network
MIIMonitorSec=500ms
UpDelaySec=1000ms
DownDelaySec=1000ms
MinLinks=1
EOF
cat >/etc/systemd/network/12-bond0-add-eth.network <<EOF
[Match]
Name=eth0
[Network]
Bond=bond0
PrimarySlave=yes
EOF
cat >/etc/systemd/network/16-bond0-add-wifi.network <<EOF
[Match]
Name=wlan1
[Network]
Bond=bond0
EOF
cat >/etc/systemd/network/20-bond0-up.network <<EOF
[Match]
Name=bond0
[Network]
# to use static IP (with your settings) toggle commenting the next 4 lines.
DHCP=yes
IPForward=yes
EOF
Creating Access Point, wlan0 (Raspi built-in wifi)
############# Create AP Access Point wlan0 ###############
cat > /etc/wpa_supplicant/wpa_supplicant-wlan0.conf <<EOF
country=US
update_config=1
network={
    ssid="My_AP"
    mode=2
    frequency=2437
    #key_mgmt=NONE   # uncomment this for an open hotspot
    # delete next 3 lines if key_mgmt=NONE
    ## Enabling key_mgmt prevents login and returns incorrect password
    #key_mgmt=WPA-PSK
    proto=RSN WPA
    psk="My_AP_Pass"
EOF
chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
systemctl enable wpa_supplicant@wlan0.service
cat > /etc/systemd/network/08-wlan0.network <<EOF
[Match]
Name=wlan0
[Network]
Address=192.168.4.1/24
DHCPServer=yes
[DHCPServer]
EOF
systemctl edit wpa_supplicant@wlan0.service
[Service]
ExecStartPre=/sbin/iptables -t nat -A POSTROUTING -o bond0 -j MASQUERADE
ExecStopPost=-/sbin/iptables -t nat -D POSTROUTING -o bond0 -j MASQUERADE
Reference
Setting up a Raspberry Pi as an access point - the easy way
How to migrate from networking to systemd-networkd with dynamic failover
Additional Information
I have tried using three different Wifi USB dongles:
  • RTL8811AU Chipset
  • RTL8188EUS Chipset
  • RTL8188EU Chipset
  • All of the above work and it does not seem to be a particular Wifi dongle that knocks out the Raspi's built-in Wifi.
    This behavior is consistent with Raspbian Stretch Lite and Raspbian Buster Lite, Raspi 3b+ and Raspi 4.
    I have tested this setup on Armbian Stretch and Armbian Buster (OPi hardware) and behavior is identical to Raspbian setup.
    Using predictable network interface naming. I have not tried to assign by MAC Address and would prefer not to in the event I would like to clone the drive and use another Raspi and/or Wifi dongle.
    Evos
    • 41
    • Thanks for your detailed feedback. I'm just checking it. At a first glance I also run into problems starting my second wifi dongle on RPi 4B, no matter if bonding or not. Haven't tested it before. Will come back. – Ingo Aug 28 '19 at 09:42
    • Thank you! I updated my post to include Wifi dongle chipsets and specific setups I've used for testing. – Evos Aug 28 '19 at 14:19
    • Sorry, but I had some problems with my test environment. There was a shortcut on the USB to TTL adapter for the debug console that confused the RasPi and the monitoring laptop. Fortunately the TTL shortcut doesn't fried my RasPi but what I commented before has another reason. Look at my answer. – Ingo Aug 28 '19 at 20:01
    Seems you have a conflict running the USB/WiFi dongle together with the built-in WiFi device. Starting with a fresh flashed Raspbian Buster Lite image first I verified on my Raspberry Pi 4B that it is working properly without bonding using this setup Access point as WiFi router/repeater with additional WiFi-dongle.
    It works.
    Then I flashed the image again and exactly used the setup you have given in your question. And what should I say?
    It also works.
    Here are some output for comparison:
    rpi ~$ ip addr
        inet6 ::1/128 scope host
    2: eth0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master bond0 state UP group default qlen 1000
        link/ether 9a:9f:4d:64:fa:0d brd ff:ff:ff:ff:ff:ff
    3: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
        inet 192.168.50.205/24 brd 192.168.50.255 scope global dynamic bond0
           valid_lft 2108sec preferred_lft 2108sec
        inet6 fe80::989f:4dff:fe64:fa0d/64 scope link
    4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
        link/ether dc:a6:32:01:db:ed brd ff:ff:ff:ff:ff:ff
        inet 192.168.4.1/24 brd 192.168.4.255 scope global wlan0
        inet6 fe80::dea6:32ff:fe01:dbed/64 scope link
    5: wlan1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master bond0 state UP group default qlen 1000
    rpi ~$ iw dev
    phy#1
        Interface wlan1
            ifindex 5
            wdev 0x100000001
            addr 9a:9f:4d:64:fa:0d
            ssid TestNet
            type managed
            channel 6 (2437 MHz), width: 20 MHz, center1: 2437 MHz
            txpower 30.00 dBm
    phy#0
        Unnamed/non-netdev interface
            wdev 0x2
            addr aa:66:d1:aa:f6:19
            type P2P-device
            txpower 31.00 dBm
        Interface wlan0
            ifindex 4
            wdev 0x1
            addr dc:a6:32:01:db:ed
            ssid RPiNet
            type AP
            txpower 31.00 dBm
    rpi ~$ cat /proc/net/bonding/bond0
    Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
    Bonding Mode: fault-tolerance (active-backup)
    Primary Slave: eth0 (primary_reselect always)
    Currently Active Slave: eth0
    MII Status: up
    MII Polling Interval (ms): 500
    Up Delay (ms): 1000
    Down Delay (ms): 1000
    Slave Interface: eth0
    MII Status: up
    Speed: 1000 Mbps
    Duplex: full
    Link Failure Count: 0
    Permanent HW addr: dc:a6:32:01:db:ec
    Slave queue ID: 0
    Slave Interface: wlan1
    MII Status: up
    Speed: Unknown
    Duplex: Unknown
    Permanent HW addr: 00:0e:00:20:08:13
    Slave queue ID: 0
    If I unplug the wired cable then my smartphone connected to the access point continued to browse the internet, means dynamic failover also works.
    • 42,107
    • 85
    • 197
    • Something is not right with my bond config. Can you post your bond0 configuration? – Evos Aug 29 '19 at 14:48
    • @Evos I don't know what I should post about the the bond0 configuration. Look at your question and you will find the setup. As already said I followed it line by line except configuring wpa_supplicant with country=DE and using ssid and psk from my location. Maybe there is a problem with your wireless connection? Does wlan0 and wlan1 work without bonding as shown in the link at my answer? – Ingo Aug 29 '19 at 15:44
    • It does not appear to be a problem with USB/Wifi, I test the connection through each section of the process. There are differences between our output: Bond mode for me returns round-robin and does not show wlan1 as a slave interface. I have to think that there must be a difference in our configurations and if not, why the output isn't similar. – Evos Aug 29 '19 at 19:58
    • Bond mode is set in /etc/systemd/network/02-bond0.netdev with Mode=active-backup. Setting this was buggy with systemd 232 comming with Raspbian Stretch. With it you have to load the bonding module with parameter direct. How to do it look at https://raspberrypi.stackexchange.com/revisions/78788/15 and search for /etc/modprobe.d/bonding.conf. But this should not be an issue because we both are using Raspbian Buster with systemd 241 that has fixed the bugs as you can see with my setup. – Ingo Aug 29 '19 at 20:51
