I've just got my first Raspberry Pi 4. I'm trying to install Raspbian's July 2019 version. I've read all related issues to this problem here and I can´t manage to find the problem.
I downloaded Raspbian with desktop from the official page: https://www.raspberrypi.org/downloads/raspbian/ And flashed it on my Kingston 32 gb Class 10 SD Card using balenaEtcher.
The first incovenient I got was the write speed I got while using balenaEtcher: between 600 and 800 kbps. When the flash finished "succesfully", a tiny warning, hidden under a red X said:
\.\PhysicalDrive1: Source and Destination checksums do not match
I didn't pay attention to this warning and proceeded to turn on my Pi anyway, and then I got the error in the title:
Kernel panic-not syncing: VFS: unable to mount root fs on unknown-block(179,2)
Reading other issues here, I tried editing cmdline.text by changing the rootfs and replace the 2 at the end with a 6, but this made my Pi stuck at the four raspberries without booting.
I also tried doing a filesystem check with fsck.ext4 on my PC with Linux mint but I got a message that said that the filesystem couldn't be found.
I think that the SD Card may be the problem but I just want to make sure it is before buying a new one, as they are not cheap where I live.
I don't know what else I can do. Thanks for your help.
EDIT:
Already run an H2testw, here we have the results:
Warning: Only 30869 of 30870 MByte tested.
The media is likely to be defective.
87.0 MByte OK (178293 sectors)
30.0 GByte DATA LOST (63041419 sectors)
Details:36.5 KByte overwritten (73 sectors)
0.5 KByte slightly changed (< 8 bit/sector, 1 sector)
30.0 GByte corrupted (63041345 sectors)
36.5 KByte aliased memory (73 sectors)
First error at offset: 0x0000000002f41010
Expected: 0x5899e01398821110
Found: 0x5899e01398821510
H2testw version 1.3
Writing speed: 7.95 MByte/s
Reading speed: 9.72 MByte/s
H2testw v1.4
Don't need to make any more clarifications, already bought a new card, thanks for your time.
Sebastian Braga
  • 461
  • I have been using different types of uSD cards, the writing speed varies from about 4Mb/s to 8/10MB/s or higher. I never saw your ridiculously low speed. – tlfong01 Aug 23 '19 at 00:56
  • So I should probably switch my SD Card? – Sebastian Braga Aug 23 '19 at 11:53
  • yes, get two class 10+ ones. – tlfong01 Aug 23 '19 at 11:57
  • Why 2? I've already bought a new one, I should receive it this afternoon, but why should I get 2? They are not that cheap where I live – Sebastian Braga Aug 23 '19 at 12:13
  • Well, I was about to suggest to use 16GB Class 10 x 2, which I think is most cost effective, unless you are doing video/image processing things. I always use two cards to swap troubleshooting. You may even consider 8GB Class 10, if it is much cheaper. Beside swap troubleshooting, it is a good idea to keep a backup copy. – tlfong01 Aug 23 '19 at 12:18
  • Here it is not cheaper to buy 2 of 16 gb, but will consider it the next time. Thanks – Sebastian Braga Aug 23 '19 at 12:20
  • I see. So in your place 32GB is perhaps the optimum. I forgot to let you know that I once worked in a factory and it is important for everything to have a spare part, or a second source, otherwise if the one and only one component breaks down, and there is no immediate replacement, we will be in big trouble. :) – tlfong01 Aug 23 '19 at 13:14
  • Yes, I know. Thought I could make backups on an old HDD I have, which has a lot of free space and I use only with that purpose and is always in a safe place. All the information that is important for me is backed up somewhere. The one I don't care too much about isn't backed up, I just bought the Raspberry for entertainment only, it is not that the information there is important – Sebastian Braga Aug 23 '19 at 13:19
  • I see, it would be fine if you have a HDD for backing up. By the way, in my place, a 16GB SD card is about US$4, compare to our minimum hourly wage of about US$5. https://imgur.com/gallery/nohT0YX. The receipt lists the barcoded serial numbers, to make sure they are not fake ones, and I forgot if is is still "life long" guarantee replacement. – tlfong01 Aug 23 '19 at 13:25
  • That's awesome. I've just finished running h2testw and mine seemsto be fake. – Sebastian Braga Aug 23 '19 at 14:08
0 Answers0
