I'm not able to run 64-bit OS on my Raspberry Pi 4. If I do these steps (https://www.raspberrypi.org/documentation/installation/installing-images/mac.md) with a 32bit OS it works fine, but if I use Ubuntu or FreeBSD then it doesn't boot. The screen keeps blank. Is there any special step when it is a 64 bit OS?
Asked
Active
Viewed 4,455 times
Perhaps have a look at https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=249248 – joan Aug 20 '19 at 17:05
1Note: FreeBSD states that there is NO (current) support for Raspberry pi 4 - does Ubuntu support it yet? – Jaromanda X Aug 20 '19 at 23:10
Quoting from FreeBSD/ARM on the Raspberry Pi family
For Raspberry Pi 4 (NOT supported yet) use the image for RPI3
You might want to try the latest FreeBSD-13.0-CURRENT-arm64-aarch64-RPI3 (410MB).
No RPI4 has been reported installed yet.
FWIW, as of Linux see Support of Raspberry Pi.
Vladimir Botka
- 136
- 4
There is no RPI4 dedicated image in CURRENT yet. Meanwhile, Wiki suggests using RPI3 images. – Vladimir Botka Aug 21 '19 at 12:00
@HolaSoyEduFelizNavidad there area a few listed here: https://raspberrypi.stackexchange.com/questions/100926/64bit-os-on-raspberry-pi-4/101802
Your title, question, and followup aren't consistent. Are you asking about any 64-bit OS for the Pi 4 or specifically FreeBSD and Ubuntu? Please edit your question to clarify.
– jdonald Aug 21 '19 at 15:51
