I looked at several solutions for this question, but none of them worked. Additionally, I tried some of the tutorials provided (with the necessary changes), but none of them worked
My aim is to use a RPi 3B+ as a router with an existing wireless router connected as an access point. The following figure explains this:
'eth0' is the Rpi's WAN port. The IP for eth0 is assigned automatically by a DHCP server that is beyond my control.
'eth1' is an 'USB to Ethernet' adapter. The wireless network is separated from the network the switch is in, by a NAT service that should run on the RPi.
I am following this tutorial as a guide. I have already configured the router as an AP.
My Problem: When I configure the network (i.e. edit the /etc/network/interfaces file) and restart the networking services (sudo /etc/init.d/networking restart), I get the following error:
Restarting networking (via systemctl): networking.serviceJob for networking.service failed because the control process exited with error code.
See 'systemctl status networking.service' and 'journalctl -xn' for details.
I also get a similar error when I try to start the DHCP server after configuration.
Starting isc-dhcp-server (via systemctl): isc-dhcp-server.serviceJob for isc-dhcp-server.service failed because the control process exited with error code.
See 'systemctl status isc-dhcp-server.service' and 'journalctl -xn' for details.
In addition, when I install isc-dhcp-server using sudo apt-get install isc-dhcp-server, it gives an error saying failed to start although it installs properly.
Can someone show me what I'm doing wrong?
EDIT: I have made a change to the setup. Instead of getting a direct connection from the ISP, I get it through a switch (hence no modem). What happens beyond the switch is none of my concern)
(2) Setting up a Raspberry Pi as a Wireless Access Point https://www.raspberrypi.org/documentation/configuration/wireless/access-point.md
(3) How to use your Raspberry Pi as a wireless access point - Stephen Lovely 2017july https://thepi.io/how-to-use-your-raspberry-pi-as-a-wireless-access-point/
(4) Setting up a Raspberry Pi 3 as an Access Point - Shawn Hymel https://learn.sparkfun.com/tutorials/setting-up-a-raspberry-pi-3-as-an-access-point/all
– tlfong01 Aug 20 '19 at 07:04
