We want to control the RPi from a distance using a laptop and a GUI.
Our idea is to do SSH tunneling. We want to do this on an ad hoc network from a windows 7 laptop.
The RPi can connect with the wifi dongle to our network but can't connect to our ad hoc network.
It keeps on scanning at the wpa gui.
Can someone help us?
Milan
I read on the Raspberry Pi website that you can create an adhoc from the Pi itself. That would be a more efficient proably. Here is the Link to the site: http://www.raspberrypi.org/forums/viewtopic.php?f=29&t=39927
Hi if you are using a different WiFi Adapter things will need adaptations. Edimax 7811UN doesn't support Adhocing past the kernel version of 3.9+.
instead using Ralink Technology based RT3570 Drivers WiFi adapters will do the trip perfectly. For further insight I had post a query and resolved it for using Pis in Adhoc Fashion on Stackoverflow Query
Better to know what adapter you are working with!
Shan-Desai
  • 1,531
You can access your RPi from anywhere around the world if you use this:
ngrok
Quick steps to get you started: (adapted from instructables.com/id/Raspberry-Pi-online-SSH-easy-way/?ALLSTEPS)
sudo wget https://dl.ngrok.com/ngrok_2.0.19_linux_arm.zip
and then unzip it using:
unzip ngrok_2.0.19_linux_arm.zip
at ngrok website go to:
dashboard.ngrok.com/user/login
and then click sign up to get an authtoken key. this token is necessary if you want your own custom domain doing an online SSH
after you manage to login you will get an authtoken key which a combination of a lot character.
You need to embed this token to your raspberry pi using:
./ngrok yourauthtoken
Now you can make your raspberry pi system to be controlled online using
./ngrok tcp 22
Using putty, enter the following IP address and port no:
By now you should be good to go!
