I created a program fairly closely related to hello_pi/hello_video.c. And for some reason after several hours of running the program I get these very strange segfaults that I cannot for the life of me figure out how to resolve. Here is what I am running:
- Raspberry PI 3B+
- Raspbian Lite (Buster)
I have checked the following:
- I am not under voltage. I am using a 5.1v 2.5a power supply from raspberry PI themselves.
- I did not over clock the system. I am sitting at 1.4 like a normal PI.
- The system has heat sinks and a fan to keep the temperature low.
- The system is also totally up to date (apt update... upgrade... rpi-update etc)
Here are a few of the errors I am receiving from the address sanitizer built into gcc:
==26987==ERROR: AddressSanitizer: heap-buffer-overflow on address 0x45009021 at pc 0x769ca548 bp 0x5a7fa474 sp 0x5a7fa040
READ of size 8 at 0x45009021 thread T450 (ILCS_HOST)
    #0 0x769ca547  (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x3a547)
Address 0x45009021 is a wild pointer.
SUMMARY: AddressSanitizer: heap-buffer-overflow (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x3a547)
Shadow bytes around the buggy address:
  0x28a011b0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a011c0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a011d0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a011e0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a011f0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
=>0x28a01200: fa fa fa fa[fa]fa fa fa fa fa fa fa fa fa fa fa
  0x28a01210: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a01220: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a01230: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a01240: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x28a01250: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
Shadow byte legend (one shadow byte represents 8 application bytes):
  Addressable:           00
  Partially addressable: 01 02 03 04 05 06 07
  Heap left redzone:       fa
  Freed heap region:       fd
  Stack left redzone:      f1
  Stack mid redzone:       f2
  Stack right redzone:     f3
  Stack after return:      f5
  Stack use after scope:   f8
  Global redzone:          f9
  Global init order:       f6
  Poisoned by user:        f7
  Container overflow:      fc
  Array cookie:            ac
  Intra object redzone:    bb
  ASan internal:           fe
  Left alloca redzone:     ca
  Right alloca redzone:    cb
Thread T450 (ILCS_HOST) created by T443 here:
    #0 0x769db9c7 in pthread_create (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x4b9c7)
    #1 0x7693b203 in vcos_thread_create /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:212
Thread T443 created by T0 here:
    #1 0x74ee1c57 in std::thread::_M_start_thread(std::unique_ptr<std::thread::_State, std::default_delete<std::thread::_State> >, void (*)()) (/usr/lib/arm-linux-gnueabihf/libstdc++.so.6+0x9dc57)
    #2 0x6bb02a7f  (<unknown module>)
==26987==ABORTING
==23420==ERROR: AddressSanitizer: SEGV on unknown address 0x0019c2c0 (pc 0x74b060f0 bp 0x74b08f3c sp 0x6acfe3b8 T2)
==23420==The signal is caused by a READ memory access.
    #0 0x74b060ef in completion_thread (/opt/vc/lib/libvchiq_arm.so+0x20ef)
AddressSanitizer can not provide additional info.
SUMMARY: AddressSanitizer: SEGV (/opt/vc/lib/libvchiq_arm.so+0x20ef) in completion_thread
Thread T2 (VCHIQ completio) created by T0 here:
    #0 0x769609c7 in pthread_create (/usr/lib/arm-linux-gnueabihf/libasan.so.5+0x4b9c7)
    #1 0x768c0203 in vcos_thread_create /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:212
==23420==ABORTING
Here is the output from gdb during those crashes:
Thread 3 "VCHIQ completio" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x6fbfeb00 (LWP 15664)]
0x751c60f0 in completion_thread () from /opt/vc/lib/libvchiq_arm.so
All the crashes seem to be related to "completion_thread()". I have no idea what that is.
Any help would be greatly appreciated!
