I have a Raspberry Pi Zero W v 1.1, to which I don't have any way to connect display adapter, therefore I communicate with it through ssh. It is connected to one isolated wifi network(with no internet access) for this connection. I need to connect it to another wifi at the same time from a different wifi adapter - connection is allowed only from certain Mac address, so I must use it - in order to have internet access. From the information I understood from here:
https://raspberrypi.stackexchange.com/a/37921
That on older raspbian versions connection was as easy as modifying the interfaces file with wpa-conf parameter. However, on new versions all things are resolved by dhcpcd.conf, where I can't find direct equivalent of this functionality. Is there any way to do this in this version, or should I just go back to old way of defining it?
