I'm having trouble getting a 1-wire sensor to be detected on my Raspberry Pi Model 3 B+. The sensor is this temperature and humidity sensor.
I have wired the red wire to 3.3V, the black wire to ground and the yellow wire to GPIO4 (physical pin 7). I have also connected a 4.7k resistor from 3.3V to GPIO4.
I have enabled 1-wire in raspi-config, and my /boot/config.txt has the dtoverlay=w1-gpio line enabled (uncommented).
The kernel modules seem to be loaded correctly:
pi@raspberrypi:~ $ lsmod | grep w1
w1_gpio 16384 0
wire 45056 1 w1_gpio
I'm running Raspbian 9 (Stretch) and my kernel version is:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
My pin configuration is:
pi@raspberrypi:~ $ gpio readall
+-----+-----+---------+------+---+---Pi 3B+-+---+------+---------+-----+-----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | ALT0 | 1 | 3 || 4 | | | 5v | | |
| 3 | 9 | SCL.1 | ALT0 | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 1 | 7 || 8 | 0 | IN | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | IN | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 0 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 0 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | IN | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | IN | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | IN | 0 | 23 || 24 | 1 | IN | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | IN | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | IN | 1 | 27 || 28 | 1 | IN | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 1 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 1 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
| 13 | 23 | GPIO.23 | IN | 0 | 33 || 34 | | | 0v | | |
| 19 | 24 | GPIO.24 | IN | 0 | 35 || 36 | 0 | OUT | GPIO.27 | 27 | 16 |
| 26 | 25 | GPIO.25 | IN | 0 | 37 || 38 | 0 | IN | GPIO.28 | 28 | 20 |
| | | 0v | | | 39 || 40 | 1 | IN | GPIO.29 | 29 | 21 |
However, no devices get detected:
pi@raspberrypi:/sys/bus/w1/devices $ ls -la
total 0
drwxr-xr-x 2 root root 0 Jul 8 13:23 .
drwxr-xr-x 4 root root 0 Jul 8 13:03 ..
lrwxrwxrwx 1 root root 0 Jul 8 13:23 w1_bus_master1 -> ../../../devices/w1_bus_master1
pi@raspberrypi:/sys/bus/w1/devices/w1_bus_master1 $ cat w1_master_slaves
not found.
I have scoped the line on GPIO4 and I do get the initial low going pulse followed by data, as expected :
Does anyone have any idea what I can try next? Or what might be going wrong?
(2) ( https://raspberrypi.stackexchange.com/questions/100203/pi-cant-find-5th-ds18b20/100244#100244 )
– tlfong01 Jul 08 '19 at 11:54(1) https://raspberrypi.stackexchange.com/questions/96560/dht11-sensor-and-the-wrong-voltage-may-have-fried-my-rpi3
(2) https://raspberrypi.stackexchange.com/questions/97949/circuit-wiring-issue
(3) https://cdn-shop.adafruit.com/datasheets/Digital+humidity+and+temperature+sensor+AM2302.pdf
(4) https://datasheet.lcsc.com/szlcsc/1906201608_Aosong-Guangzhou-Elec-AM2105A_C394878.pdf
(5) https://www.raspberrypi.org/forums/viewtopic.php?f=37&t=77158&hilit=DHT11&start=350#p1355567
– tlfong01 Jul 09 '19 at 02:08
