UPD: with another chip of the same model RTC works just fine, presumably that the chip was broken/damaged.
I installed DS3231 RTC clock ( which is detected as DS1307 for some reason). My config.txt looks like
gpu_mem=64
dtoverlay=dwc2
dtoverlay=i2c-rtc,ds3231
dtparam=i2c_arm=on
dtparam=i2c_arm_baudrate=1000000
dtparam=spi=on
enable_uart=1
The clock is detected by i2cdetect and I can see that /dev/rtc0 exists.
dmesg | grep rtc shows
dmesg | grep rtc
[    4.021947] rtc-ds1307 1-0068: registered as rtc0
The problem is - hwclock -r always returns the same time. I can set it with hwclock -w and it will keep that very time for weeks.
Am I missing something there? Isn't it supposed to tick?
jdevelop
  • 113
The ONLY thing you have to do is include in /boot/config.txt:
All the RTC supported by the Pi kernel use the same rtc-ds1307 driver, but you NEED to tell the driver which chip you actually have. (The different chips have similar instruction sets and registers.)
NOTE you NEED to use a separate dtoverlay line for each overlay. Putting dwc2,i2c-rtc will not work.
There is no need to set time - it all happens AUTOMATICALLY, although you can set the RTC initially (if NTP not available) using hwclock --set see man hwclock for details.
See https://raspberrypi.stackexchange.com/a/51782/8697
