The question says it all. If you have a definite answer, it would be great if you could post a photo of the pi zero, where the fuse is pointed out.
SlySven
  • 3,621
  • 45
Stowoda
  • 446
The Pi Zero does not have a fuse (polyfuse or otherwise).
See this Raspberry Pi org forum post.
Also see these limited schematics.
joan
  • 71,024
  • 73
  • 106
NO polyfuse for raspberry pi zero
Thanks to Joan I got the information to complete this request. Here are the schematics for the power supply of both raspberry pi Zero and PRI 3, .
Raspberry Pi Zero without fuse:
And Here for comparision RPI3 with polyfuse:
Stowoda
  • 446
  • So: on the bright side the RPi Zero is not going to suffer from volt-drop to the same extent when power is drawn from the +5V pins on the GPIO connections...! – SlySven Jul 11 '17 at 15:34
It does not have a polyfuse, but good fuses are cheap. If you want a fuse, use a nice glass fuse: fuse1
Or a tiny fuse: fuse2
To check if you've popped it, just use an ohm measurement. You also do not have to waste a day or more praying that your polyfuse has saved you.
Or add your own polyfuse: fuse3
user2497
  • 679
  • Of course you will have to use the right fuse (for a fuse of current rating Iₙ you will need to draw at least 2 * Iₙ and possibly more to get it to fuse in a reasonable time) and as far as semiconductor equipment with a glass/ceramic fuse you can often find that the circuit will work fine without any of that nasty volt-drop associated with poly-fuses - it is just that in the event of an over-voltage or down-stream overload the semiconductors protect the fuse by burning out in an open-circuit manner so as to not cause the fuse to blow... 8-P – SlySven Oct 24 '17 at 00:06
  • @SlySven Yes, a fast fuse. The right fuse. I like glass-case fuses in proper fuse mountings. Polyfuses are silly. – user2497 Oct 24 '17 at 00:08
